Tasneetpc
Mar 23, 2020Aspirant
RSync Backup Local to remote fails
I have configured a Rsync to copy the local data to Remote .Both are RN3312 models and connected across the firewall. Connectivity is OK and when I start the Job, errors are thrown and it fails i...
- Mar 23, 2020
The usual cause for this is not haviing Rsync write access enabled on the target. The default is read-only.
The check done to verify the connection does not check that the share has write access, it only checks that the target is reachable.
Sandshark
Mar 23, 2020Sensei
Tasneetpc
Read /Write access in the destination folder is given already .Refer the screenshot.
