Tasneetpc
Mar 23, 2020Aspirant
RSync Backup Local to remote fails
I have configured a Rsync to copy the local data to Remote .Both are RN3312 models and connected across the firewall. Connectivity is OK and when I start the Job, errors are thrown and it fails i...
- Mar 23, 2020
The usual cause for this is not haviing Rsync write access enabled on the target. The default is read-only.
The check done to verify the connection does not check that the share has write access, it only checks that the target is reachable.
Issovits
Hi,
I got some rsync problems with 6.10.3 on my NAS. The names i give my NAS-Systems are overwritten within 24 hours in Rsync so that the sync jobs won't work automatically. I got that problem on my RN104 for some time now but it only happens on connection issuses from the power supply. (got aware of it with an USV, still this is my beta tester and has aome other problems too) Now my RN 204 is also making this bad habbit within 24 hours after upgrading to 6.10.3.
Just don't upgrade to this Version if you have an Arm based NAS that works. I think there are more issues with this Version (what i could see in beta Forum). I hope Netgear is working on that Problem cause they haven't made an free beta-test with this software. I try going back to 6.10.2 until this is solved or Netgear gives some Information in the Forum for these Bugs.
