przemek_ch
Jan 08, 2013Aspirant
rsync (DeltaCopy) vs Windows/NAS (Timestamp)
Which protocol will be better for a Winows share to Nas backup . What are the main differences between rsync and Windows/NAS (Timestamp)? I need a backup solution for my 400gb photo catalog. rsync...
przemek_ch
Jan 11, 2013Aspirant
I've used free DeltaCopy rsync server on my Winows8 64bit.
You need to disable windows firewall or open 873 port - otherwise You won't be able to connect.
But as I said - every time I copy something from windows to Nas share all the permissions are removed form the share folder.
BTW there is a second bug in raidator 5.3.5 - if the connection string in the rsync backup preferences will be wrong after You perform the connection test it will show "sucess" :) But the backup will fail anyway :)
