nevesn
Apr 13, 2016Aspirant
Rsync email alerts
I have RSYNC setup between two of my ReadyNAS 314 and am receiving email alerts on failed backup but nothing on successful ones. Is it possible to get email alerts on successful RSYNC backups?
- Apr 14, 2016
Thanks a bunch!
nevesn
Apr 14, 2016Aspirant
Hi Brian thanks for the reply. I don't see an Options tab though. I see tabs like Overview, Performance, Settings, Logs, Volume sand Power and also System , Shares, Iscsi, Backup, Accounts, Network, cloud and Apps.
Apr 14, 2016Guru - Experienced User
First click on the backup tab.
Then select the specific backup job. There will be a settings wheel on the far right. Click on it. That should give you this:
- nevesnApr 14, 2016Aspirant
Thanks a bunch!
- BrianL2Apr 14, 2016NETGEAR Employee Retired
Hi nevesn,
You're welcome.It seems that this thread is marked closed and we hope that you will continue to be an active member of the community. Feel free to post any suggestions, questions, recommendations or anything about your ReadyNAS that you think needs attention and will help others.Kind regards,BrianL
NETGEAR Community Team
