vandermerwe
Apr 10, 2017Master
Rsync error read only filesystem(30)
My rsync backups have been running flawlessly for years being pulled from a 316 to a Ultra 6+. Both units are running 6.7.0. For the last 2 days, backups are failing, all with the same error, - ...
jak0lantash
Apr 10, 2017Mentor
vandermerwe wrote:
Ready DR backups to the same Ultra 6+ are also failing with an input/output error.
So, I presume you installed OS6 on it.
If you download the logs and look at btrfs.log, do you see the data volume being fully allocated?
Any error in systemd-journal.log?
vandermerwe
Apr 10, 2017Master
Label: '33ea9931:root' uuid: dff4e5dd-d198-401a-b8bf-09915591d8cd
Total devices 1 FS bytes used 544.79MiB
devid 1 size 4.00GiB used 1.63GiB path /dev/md0
Label: '33ea9931:data' uuid: 5a9c472f-3757-4e79-b6b8-90792440712b
Total devices 1 FS bytes used 6.75TiB
devid 1 size 9.07TiB used 6.76TiB path /dev/md127
=== filesystem /data ===
Data, single: total=6.76TiB, used=6.75TiB
System, DUP: total=32.00MiB, used=768.00KiB
Metadata, DUP: total=2.00GiB, used=1.00GiB
GlobalReserve, single: total=352.00MiB, used=7.00MiB
There are many errors in systemjournal about failing to delete snapshots and this:
Apr 10 21:01:11 backupnas kernel: BTRFS: error (device md127) in create_pending_snapshot:1545: errno=-5 IO failure
Apr 10 21:01:11 backupnas kernel: BTRFS info (device md127): forced readonly
Apr 10 21:01:11 backupnas kernel: BTRFS warning (device md127): Skipping commit of aborted transaction.
Apr 10 21:01:11 backupnas kernel: BTRFS: error (device md127) in cleanup_transaction:1843: errno=-5 IO failure
Apr 10 21:01:11 backupnas kernel: ------------[ cut here ]------------
and this:
Apr 10 21:01:11 backupnas replisync[3057]: daemon: _splice error: Broken pipe
Apr 10 21:01:11 backupnas replisync[2863]: ERROR: creating snapshot KIDNASDR/.snapshots/618/snapshot -> snapshot failed: Input/output error
Apr 10 21:01:11 backupnas replisync[3057]: daemon: _btrfs_receive error: Broken pipe
Apr 10 21:01:11 backupnas replisync[2863]: ERROR: truncate Private practice/Copies of lists/2017/20170323 selvey.pdf failed: Read-only file system
Apr 10 21:01:11 backupnas replisync[3056]: daemon: _splice error: Broken pipe
Apr 10 21:01:11 backupnas replisync[2863]: ERROR: creating snapshot CSDNASDR/.snapshots/1075/snapshot -> snapshot failed: Input/output error
Apr 10 21:01:11 backupnas replisync[3055]: daemon: _splice error: Broken pipe
Apr 10 21:01:11 backupnas replisync[2863]: daemon: _splice error: Broken pipe
Apr 10 21:01:11 backupnas replisync[3055]: daemon: _btrfs_receive error: Broken pipe
Apr 10 21:01:11 backupnas replisync[2863]: ERROR: creating snapshot EADNASDR/.snapshots/1074/snapshot -> snapshot failed: Input/output error
Apr 10 21:01:11 backupnas replisync[3056]: daemon: _btrfs_receive error: Broken pipe
Apr 10 21:01:11 backupnas replisync[3058]: daemon: _splice error: Broken pipe
Apr 10 21:01:11 backupnas replisync[3058]: daemon: _btrfs_receive error: Broken pipe
Apr 10 21:15:51 backupnas readynasd[3078]: ERROR: failed to lookup path for root 7734: Input/output error
Apr 10 21:15:51 backupnas kernel: BTRFS error (device md127): parent transid verify failed on 120651776 wanted 13617 found 13384
Apr 10 21:01:11 backupnas replisync[2863]: ERROR: failed to make subvolume read only: Read-only file system
and then also
Apr 10 21:09:23 backupnas fvbackup-q[3644]: cmd=/frontview/bin/fvbackup -e 2
Apr 10 21:09:29 backupnas readynasd[3078]: Error backup job EADNAS: failure during copy.
I don't understand what these mean, there are numerous similar error messages regarding the readydr jobs and the rsync jobs that are failing.
The backup job error logs all say this:
Failed to run rsync, return rc 5888 (23)
'rsync' command returns rc=5888
- jak0lantashApr 10, 2017Mentor
vandermerwe wrote:Label: '33ea9931:data' uuid: 5a9c472f-3757-4e79-b6b8-90792440712b
devid 1 size 9.07TiB used 6.76TiB path /dev/md127=== filesystem /data ===
GlobalReserve, single: total=352.00MiB, used=7.00MiBThis is OK.
vandermerwe wrote:Apr 10 21:01:11 backupnas kernel: BTRFS: error (device md127) in create_pending_snapshot:1545: errno=-5 IO failure
Apr 10 21:01:11 backupnas kernel: ------------[ cut here ]------------This is not very good, though I'd need a full trace (this is just a few lines of one) to say more.
The second line tells you that BTRFS is falling back to read-only, which is why you have the other issues.
vandermerwe wrote:Apr 10 21:15:51 backupnas kernel: BTRFS error (device md127): parent transid verify failed on 120651776 wanted 13617 found 13384
Apr 10 21:15:51 backupnas kernel: BTRFS error (device md127): parent transid verify failed on 120651776 wanted 13617 found 13384I'm afraid this is filesystem corruption. Afaik, it's really not easy to fix in place. Instead, an easier way would be to perform a full backup and recreate the volume.
- vandermerweApr 10, 2017Master
OK.
I can recreate the volume.
I will test all the disks with vendor tools too.
Why would this happen out of the blue - the disks are OK, the nas is supported by an UPS and there have been no power issues.?
- jak0lantashApr 11, 2017Mentor
I don't know, sorry.
