Jeff_howard
Nov 25, 2017Aspirant
Rsync errors
I am getting errors with my Rsync errors. Nothing has changed in my setup or settings. Any Ideas? This is a backup job between two identical NAS box's RN314 with latest firmware 6.9.0 Both hav...
Nov 26, 2017Guru - Experienced User
My own rsync backups worked with no issue on 6.9.0.
Though you likely already did this, you might confirm that destination NAS IP address didn't change. If the NAS use NIC bonding, perhaps try temporarily breaking the bond.
You could also try rebooting the destination, and see if that makes any difference.
Jeff_howard
Nov 27, 2017Aspirant
Both NAS boxes had bonded NIC connections. I have removed the Bonded settings and will try again.
Thanks. Is this a issue with the latest firmware?
