Jeff_howard
Nov 25, 2017Aspirant
Rsync errors
I am getting errors with my Rsync errors. Nothing has changed in my setup or settings. Any Ideas? This is a backup job between two identical NAS box's RN314 with latest firmware 6.9.0 Both hav...
Jeff_howard
Nov 27, 2017Aspirant
Both NAS boxes had bonded NIC connections. I have removed the Bonded settings and will try again.
Thanks. Is this a issue with the latest firmware?
Nov 27, 2017Guru - Experienced User
There were issues with bonding - and Netgear pushed out some hot fixes. I think there are more network fixes in 6.9.1, so you might want to upgrade to that.
- Jeff_howardNov 27, 2017Aspirant
I don't see the 6.9.1 is avalible yet. Is it still in Beta?
- StephenBNov 27, 2017Guru - Experienced User
No, it is released - but I don't think it's being pushed through the update servers quite yet. You can get a manual install here: https://kb.netgear.com/000051531/ReadyNAS-OS-6-Software-Version-6-9-1
