msd
Oct 11, 2014Luminary
Rsync fails - How to Reset Permissions on a USB Drive?
Hi, ReadyNas 312 Firmware 6.1.9 Rsync fails due to Error = failed: Read-only file system (30) (on USB drive) Silly part is the original backup was using Rsync however when I plug the USB drive back...
mdgm-ntgr
Oct 11, 2014NETGEAR Employee Retired
Yes, I browse these forums a lot.
Did you safely unmount the USB disk when disconnecting it?
Personally I would recommend EXT4 over NTFS.
