msd
Oct 11, 2014Luminary
Rsync fails - How to Reset Permissions on a USB Drive?
Hi, ReadyNas 312 Firmware 6.1.9 Rsync fails due to Error = failed: Read-only file system (30) (on USB drive) Silly part is the original backup was using Rsync however when I plug the USB drive back...
mdgm-ntgr
Oct 11, 2014NETGEAR Employee Retired
Yes solutions over workarounds are better.
Hopefully it works smoothly now, but sometimes if a filesystem gets badly messed up then a format can be the best way to go.
