msd
Oct 11, 2014Luminary
Rsync fails - How to Reset Permissions on a USB Drive?
Hi, ReadyNas 312 Firmware 6.1.9 Rsync fails due to Error = failed: Read-only file system (30) (on USB drive) Silly part is the original backup was using Rsync however when I plug the USB drive back...
mdgm-ntgr
Oct 11, 2014NETGEAR Employee Retired
Well I think the OS6 behaviour is better then.
If a filesystem on the USB disk has errors there could be problems with the backup which is something you want to know about.
Your welcome. Yes it is going well.
