shardie
Dec 02, 2018Aspirant
RSync fails... Any idea why?
Hi All... Im trying to backup one NAS to another NAS using RSync but it just keeps failing.
So the main NAS is a ReadyNAS 2304 backu to ReadyNAS 2120 v2. oth have the same firmware versions. I ...
- Dec 03, 2018
ITS WORKING NOW
Okay so what I did was from the host (backup) NAS I created a BACKUP shared folder and enabled RSync, but I made sure that READ/WRITE was selected in the security tab....
Now its working..
Marc_V
Dec 03, 2018NETGEAR Employee Retired
Hi shardie
Are the shares on both NAS has RSYNC enabled? Also please check your DNS entries on Network Settings.
Have you tried setting the backup on the destination to pull the data to it?
Regards
- shardieDec 03, 2018Aspirant
Thanks for the reply....
Yes RSync is active on both NAS's, and noth find each other in the setup.....
What I nocticed is that it gives an error if I choose the ROOT of the drive but it works only if I choose a Folder. I dont want to choose seperate folders but the whole drive.
If I make the path just {name of volume} I get a permission error.
ITS WORKING NOW
Now its working..
