eton
Jan 22, 2011Luminary
rsync folder exclusion tips
I just would like to share my reasearch on how to exclude a folder with rsync. The man pages uses the form FolderName/, but that excludes all folders with that name whereever they are stored on the b...
eton
Feb 15, 2015Luminary
XAffi wrote:
Sorry for the late reply. had some issues with the ISP...
The web interface does not support this as well... Can you tell me where to edit it if login directly to the NAS?
I have a ReadyNAS Duo v1 with RAIDiator 4.1.13 firmware. Tried to find the file with rsync settings with:
# find / \( -path /c -o -path /proc -o -path /USB \) -prune -o -type f -size -5k -exec grep -IHn '/media/BitTorrent/' {} 2>&1 \; But it finished with zero results.Some research shows that RAIDiator/Frontview encodes paths and that most of Frontviews settings are stored under /etc/.
# find /etc/ -type f -exec grep -IHn '%20Name' {} 2>&1 \;
/etc/cron.d/frontview-backup:1:5 04-23/24 * * mon,tue,wed,thu,fri root /frontview/bin/backup 001 enable 'local!!c!!!!!!!!' 'remote!!rsync!!localhost\%3A\%3AUSB\%5FHDD\%5F1!!!!!!' 'FIRST_TIME!!0!!0!!1!!0!!\%2Fmedia\%2FBitTorrent\%2F\%2C\%2Fmedia\%2FTemp\%2F\%2D\%5C\%20Name\%2F!!0' &> /dev/nullThe selectable shares list for backup jobs is located here:
/etc/frontview/rsync/Shares.conf
