ElPablo2
Jan 29, 2018Aspirant
rsync in 6.9.2 subdirectory
After upgrading to 6.9.2 I've noticed that rsync backup jobs that have a share subdirectory as a source don't seem to be running correctly. They complete almost immediately, nothing is copied, and th...
ElPablo2
I probably should have added a bit more detail. It's a local backup to USB using rsync and it's been working well for quite a long time now. Nothing has changed except for 6.9.1 and 6.9.2 updates. First upgrades in a long time.
Jan 29, 2018Guru - Experienced User
Does anything change if you set the port to 873?
- ElPablo2Jan 29, 2018Aspirant
Nothing changes when I change the port to 873. rsync doesn't even seem to run. Usually, I can see rsync and fvbackup in top or in ps.
- mdgm-ntgrJan 29, 2018NETGEAR Employee Retired
Can you try running the job again then download your logs and send them in (see the Sending Logs link in my sig)?
- Mar 10, 2018Retired_Member
