walterwerner
Sep 25, 2009Aspirant
rsync of iSCSI
I've been trying to find this and have not been successful. Can someone describe the steps to backup from one readynas 2100 to another readynas 2100 using rsync where I want to backup a iSCSI targe...
ewok
Sep 29, 2009NETGEAR Expert
walterwerner wrote: So, you didn't answer the question... do I need to create the iScsi target on the remote server?
I guess I should have been more clear. Short answer: no, you don't need to create an iSCSI target for the backup. Longer answer: no, don't create it, because backing up an iSCSI target using the backup manager will not result in an available iSCSI target on the backup destination. The backup treats the iSCSI disk image as a standard file, and will copy it to a local or remote share, which is not where the iSCSI target disk images are stored on the ReadyNAS.
