walterwerner
Sep 25, 2009Aspirant
rsync of iSCSI
I've been trying to find this and have not been successful. Can someone describe the steps to backup from one readynas 2100 to another readynas 2100 using rsync where I want to backup a iSCSI targe...
joco_ph
Jan 22, 2013Aspirant
hi, im new to the forum and stubled on this thread... can some one elaborate on this?
"To make the disk image into a target, create the target on the remote ReadyNAS, use the backup manager to back the disk image up to a share, then connect to the data volume share (normally C) as the admin user and move the disk image to the root of the data volume. You would need to restart the iSCSI server for the change to take effect."
i already backed up a LUN to a remote rsync server. It created a large file on the remote server. How do i make it a target?
1. create the target on the remote ReadyNAS - this is an iscsi target right?
2. use the backup manager to back the disk image up to a share - can you show step by step?
3. then connect to the data volume share (normally C) as the admin user and move the disk image to the root of the data volume = please show step by step.
4. You would need to restart the iSCSI server for the change to take effect." = please show step by step
thanks.
thanks.
