cassko
Jun 29, 2016Aspirant
Rsync or relicate
Hi. I am going to make a backup between two ReadyNases (RN102 and RN214) over wan. I am a bit uncertain if I should use Rsync or replicate. What are the pros and cons of Rsync and replicate? ...
- Jul 01, 2016
Replicate uses ReadyCloud VPN technology (Remote) to connect. Netgear doesn't provide enough information on Remote to compare its security to rsync over ssh. That said, rsync over ssh should be quite secure.
Replicate is easier to set up. Rsync over ssh doesn't depend on cloud services.
omicron_persei8
Jun 30, 2016Luminary
Replicate uses rsync. It creates a VPN between both units and use that for the rsync job.
If you want to have full control of the job, use rsync and do it yourself. If you want to be able to set it up in a few clicks, use replicate ;)
