cassko's avatar
cassko
Rsync or relicate
Hi.   I am going to make a backup between two ReadyNases (RN102 and RN214) over wan. I am a bit uncertain if I should use Rsync or replicate. What are the pros and cons of Rsync and replicate?   ...
  • StephenB's avatar
    Jul 01, 2016
    Replicate uses ReadyCloud VPN technology (Remote) to connect.  Netgear doesn't provide enough information on Remote to compare its security to rsync over ssh.  That said, rsync over ssh should be quite secure.
    Replicate is easier to set up.   Rsync over ssh doesn't depend on cloud services.
ProSupport for Business
