jhaye1
Oct 16, 2013Aspirant
RSYNC over SSH backup using a different port - OS 6.1.2
Hi There My environment: ReadyNAS RN102 OS: 6.1.2 My goal: Have an RSYNC-over-SSH backup job configured and running on my ReadyNAS, towards an RSYNC server that uses another port tha...
chirpa
Oct 16, 2013Luminary
If you are good with SQL(lite), you can try changing the port in the database itself, there is a field for it.
# sqlite3 /var/readynasd/db.sq3
SQLite version 3.7.17 2013-05-20 00:56:22
Enter ".help" for instructions
Enter SQL statements terminated with a ";"
sqlite> .headers ON
sqlite> select * from backup;
id|name|enabled|sch_every|sch_start|sch_end|sch_dow|src_type|src_share_proto|src_path|src_login|src_password|src_port|src_eject|dst_type|dst_share_proto|dst_path|dst_login|dst_password|dst_port|dst_eject|opt_full_backup_freq|opt_remove_previous_backup|opt_chown_to_share_owner|opt_rsync_options|opt_email_this_to_alert_email|opt_rsync_exclude|opt_misc_option|wol_addr
1|test|1|24|21|23|62|share|backup|directory|||0|0|remote|rsync+ssh|128.203.202.1://remote/path|root||0|0|FIRST_TIME|0|0|2|0||0|
