dacarson
Oct 03, 2022Aspirant
RSync over SSH failing without logs or details
MacOS Photos requires that you store your photos in their special filesystem. My MacOS doesn't have sufficient disk space to store all my photos and I would like them to be backed up. I created a di...
dacarson
Thanks for your help.
RSync over SSH was working just fine, so I am not sure why it is now failing, and I don't know how to get ReadyNAS to provide to me a detailed failure description. All I get is that 'it failed'.
If there was a location on the ReadyNAS where I could log in and see a full transcript of the Backup job, that would be helpful. Or even if there was a way to get the command line that the ReadyNAS runs, I could try running it manually myself from the console on the ReadyNAS I could see where it failed.
I have not tried it the other way, ie run the job on the Mac as I don't have a good way to schedule jobs on the mac. Let me look into FreeFileSync. (Though it is unfortunate that the tools provided by ReadyNAS that I paid for as part of my ReadyNAS don't work)
Oct 03, 2022Guru - Experienced User
dacarson wrote:RSync over SSH was working just fine, so I am not sure why it is now failing, and I don't know how to get ReadyNAS to provide to me a detailed failure description. All I get is that 'it failed'.
So this exact scenario was working before (using an rsync-over-ssh backup job to pull files from a remote MacOS disk image)?
Are you seeing any photos in the destination share?
This isn't as much information as there could be here. Backups are run using a Netgear backup utility (/frontview/bin/fvbackup). As far as I can tell, that generates the actual backup command(s) on the fly. There are some logs in /var/log/frontview/backup/, but they don't have the info you are looking for. journalctl --no-pager | grep -i rsync might give you a little info - but in my experience, not a whole lot.
You might be able to catch the command line from ssh using something like ps -aux | grep -i rsync if you can enter this while the backup job is running.
FWIW, I am thinking the actual problem is on the mac side. The NAS can connect to the rsync daemon there, but that doesn't mean that the rsync daemon is configured to access the files in the disk image. But as I said earlier, I'm not a mac user.
- dacarsonOct 03, 2022Aspirant
Thank you. I think I found the issue:
root@ReadyNas:~# cat /var/log/frontview/backup/backup_001_error.log
Failed to run rsync, return rc 23
rsync: opendir "/Volumes/DavidPhotosBig/.TemporaryItems" failed: Permission denied (13)
- StephenBOct 03, 2022Guru - Experienced User
dacarson wrote:root@ReadyNas:~# cat /var/log/frontview/backup/backup_001_error.log
So a permissions issue on the mac side. You could try excluding .TemporaryItems in the backup job settings. Though the permissions might still be a problem with the remaining files/folders.
Not sure why the ReadyNAS doesn't expose this error to me, but I am glad there was a way to find it.
.TemporaryItems is a special file that MacOS uses. Hopefully the rest of the permissions are fine.
