troystanway
May 17, 2014Tutor
Running a SSH Command at boot
I was wondering if you could help me a little bit. I have installed utorrent server for Debian 7 x64, through ssh commandline on my ReadyNAS 314 OS6.1.8 To start utorrent server, i need to run thi...
troystanway
May 17, 2014Tutor
I tried writing the config.xml like this:
But it still doesnt start the utorrent command and gives me an error when I toggle it in the frontview.
<Application resource-id="utorrent-server-alpha-v3_3"><!-- 'resource-id' must be AppName -->
<Name>uTorrent Server</Name><!-- Any desciptive name, upto 48 chars -->
<Author>Random</Author><!-- Authors name. upto 48 chars -->
<Version>3.3 build 30470</Version><!-- Version -->
<RequireReboot>0</RequireReboot><!-- If non-zero, it indicate reboot is required. -->
<LaunchURL>http://localhost:8080/gui</LaunchURL><!-- 'localhost' will be replaced by framework JS. -->
<ConfigURL></ConfigURL>
<ReservePort>8080</ReservePort>
<ServiceName>utserver -settingspath /apps/utorrent-server-alpha-v3_3/</ServiceName>
<Description lang="en-us">uTorrent Server: A torrent downloader.</Description>
</Application>
