JasperA
May 21, 2016Apprentice
Safe to hard reboot while balancing is running?
I have upgraded my RN516 to 6.5.0 and some weird problem started. Logitechmediaserver didn't work anymore. After logging in I discovered the / filesystem was not writable because there seemed to be '...
- May 25, 2016
It's broken due to general packaging violations in the lms-1.08 package. Please purge it (`dpkg -P lms`) before doing anything else. For LMS functionality, you'll want to switch to the much nicer and cleaner "Logitech Media Server NT" package from our Apps library.
mdgm-ntgr
May 23, 2016NETGEAR Employee Retired
The logs you sent are flooded with messages like this:
May 24 00:11:15 truck systemd[1]: systemd-pdns.service holdoff time over, scheduling restart.
May 24 00:11:15 truck systemd[1]: Cannot add dependency job for unit network-online.target, ignoring: Unit network-online.target failed to load: No such file or directory. See system logs and 'systemctl status network-online.target' for details.
May 24 00:11:15 truck systemd[29309]: Failed at step EXEC spawning /usr/sbin/pdns_server: No such file or directory
May 24 00:11:15 truck systemd[1]: systemd-pdns.service: control process exited, code=exited status=203
May 24 00:11:15 truck systemd[1]: Unit systemd-pdns.service entered failed state.
So perhaps you should start by removing that systemd-pdns.service file.
Then look into removing the packages properly.
JasperA
May 24, 2016Apprentice
Removed the pdns service files and the filling of /var/tmp with systemd-private-xxxxxx directories has stopped!
However, I am unable to remove the apps I installed. It just says 'System: Cannot uninstall application Logitech Media Server.'
I guess I should run the 'apt-get -f install' command like suggested, to meet the dependencies.
- JasperAMay 24, 2016Apprentice
root@truck log# apt-get -f install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following extra packages will be installed:
libc6-i386
The following packages will be upgraded:
libc6-i386
1 upgraded, 0 newly installed, 0 to remove and 77 not upgraded.
5 not fully installed or removed.
Need to get 0 B/2386 kB of archives.
After this operation, 10.2 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
(Reading database ... 36783 files and directories currently installed.)
Preparing to replace libc6-i386 2.19-13.netgear1 (using .../libc6-i386_2.19-18+deb8u3.netgear1_amd64.deb) ...
Unpacking replacement libc6-i386 ...
dpkg: error processing /var/cache/apt/archives/libc6-i386_2.19-18+deb8u3.netgear1_amd64.deb (--unpack):
trying to overwrite '/lib/ld-linux.so.2', which is also in package lms 1.0.8
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@truck log# ll /lib/ld-linux.so.2
lrwxrwxrwx 1 root root 20 Nov 8 2015 /lib/ld-linux.so.2 -> /lib32/ld-linux.so.2*
root@truck log# ll /lib32/ld-linux.so.2
lrwxrwxrwx 1 root root 10 Feb 6 2015 /lib32/ld-linux.so.2 -> ld-2.19.so*
root@truck log# ll /lib32/ld-2.19.so
-rwxr-xr-x 1 root root 134308 Feb 6 2015 /lib32/ld-2.19.so*Should I just force it?
- SkywalkerMay 25, 2016NETGEAR Expert
- JasperAMay 26, 2016Apprentice
Indeed, removing the lms package did the trick. That and removing remains of pdns and syslog-ng which I installed previously. /var/tmp isn't filling up with subdirs anymore and the NAS seems happy.
Thanks for the support.
