JasperA
May 21, 2016Apprentice
Safe to hard reboot while balancing is running?
I have upgraded my RN516 to 6.5.0 and some weird problem started. Logitechmediaserver didn't work anymore. After logging in I discovered the / filesystem was not writable because there seemed to be '...
- May 25, 2016
It's broken due to general packaging violations in the lms-1.08 package. Please purge it (`dpkg -P lms`) before doing anything else. For LMS functionality, you'll want to switch to the much nicer and cleaner "Logitech Media Server NT" package from our Apps library.
JasperA
May 24, 2016Apprentice
root@truck log# apt-get -f install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following extra packages will be installed:
libc6-i386
The following packages will be upgraded:
libc6-i386
1 upgraded, 0 newly installed, 0 to remove and 77 not upgraded.
5 not fully installed or removed.
Need to get 0 B/2386 kB of archives.
After this operation, 10.2 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
(Reading database ... 36783 files and directories currently installed.)
Preparing to replace libc6-i386 2.19-13.netgear1 (using .../libc6-i386_2.19-18+deb8u3.netgear1_amd64.deb) ...
Unpacking replacement libc6-i386 ...
dpkg: error processing /var/cache/apt/archives/libc6-i386_2.19-18+deb8u3.netgear1_amd64.deb (--unpack):
trying to overwrite '/lib/ld-linux.so.2', which is also in package lms 1.0.8
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@truck log# ll /lib/ld-linux.so.2
lrwxrwxrwx 1 root root 20 Nov 8 2015 /lib/ld-linux.so.2 -> /lib32/ld-linux.so.2*
root@truck log# ll /lib32/ld-linux.so.2
lrwxrwxrwx 1 root root 10 Feb 6 2015 /lib32/ld-linux.so.2 -> ld-2.19.so*
root@truck log# ll /lib32/ld-2.19.so
-rwxr-xr-x 1 root root 134308 Feb 6 2015 /lib32/ld-2.19.so*
Should I just force it?
Skywalker
May 25, 2016NETGEAR Expert
- JasperAMay 26, 2016Apprentice
Indeed, removing the lms package did the trick. That and removing remains of pdns and syslog-ng which I installed previously. /var/tmp isn't filling up with subdirs anymore and the NAS seems happy.
Thanks for the support.
