JasperA
May 21, 2016Apprentice
Safe to hard reboot while balancing is running?
I have upgraded my RN516 to 6.5.0 and some weird problem started. Logitechmediaserver didn't work anymore. After logging in I discovered the / filesystem was not writable because there seemed to be '...
- May 25, 2016
It's broken due to general packaging violations in the lms-1.08 package. Please purge it (`dpkg -P lms`) before doing anything else. For LMS functionality, you'll want to switch to the much nicer and cleaner "Logitech Media Server NT" package from our Apps library.
Piglet
May 26, 2016Luminary
I had pretty much the exact same problem a year ago: I initiated a restart while a balance was running, which caused the system to hang. I eventually had to force reboot my system (after waiting two weeks!) and the end result was a damaged filesystem. I had to do a full reformat. I managed to salvage most but not all of the data, but it cost a lot of time.
I was told the problem with balance preventing reboots would be fixed in a future update. But I guess that hasn't been done. (This was on OS 6.2.2)
- SkywalkerMay 26, 2016NETGEAR Expert
Balance doesn't prevent reboots. That had nothing to do with the issue here. This issue was the result of bad interaction between improperly-packaged apps and manually installed extra packages.
