mdgm-ntgr
Feb 05, 2011NETGEAR Employee Retired
SBS 2011 and ESXi
I was thinking of maybe getting a ReadyNAS to use as NFS storage for a new ESXi server to replace any ageing setup. Which ReadyNAS would you recommend for this new setup? Currently we're using an a...
mdgm-ntgr
May 12, 2011NETGEAR Employee Retired
bbaraniec wrote:
Should I get SAS disks (if so which ones) or enterprise SATA disks.
If you need 10rpm or more then go SAS. If 7200 is enough and judging by the amount of users it will be then go wirh SATA.
Another note, I have 6 servers with SAS drives (HP DL 380 G5 and G6) and around 10 with SATA drives. In last 4 years dead ratio SAS:SATA is 0:3
So why not go with SAS then as they are more reliable?
bbaraniec wrote:
Also I was thinking using ESXi would be a better way of doing things in case we wish to get the Premium Add-on down the track and also to make it easier to move to a new server if the current server fails.
That's for sure. I have 5 ESXi servers running with 8 OS on each. Migrating machines is easy and fast.
Good!
bbaraniec wrote:
I'd like to be able to separate hardware upgrades from OS upgrades when it comes to the server. As an SBS migration is a time consuming task.Any advice on how to migrate from SBS 2003 to 2011 such as good sites to look at?
Well depends what you have running there.
Also how much downtime will this lead to?
Also depends what you have running. AD, file server, print server, Exchange, SharePoint you can migrate really with really short or no downtime at all.
I have AD, file server, Papercut (print charging software), Exchange, some Time & Cost software and an accounting program that uses SQL.
- Jul 18, 2017Retired_Member
