Retired_Member
Jul 18, 2017ReadyNAS Balance and ESXI hosts
Model ReadyNAS 4312 (did not have that in Model selection, when creating this discussin).
Firmware 6.7.5
*My "setup"
ESXi 6.0
EMC SAN for Production Servers (10GB Base-T)
Readynas 4312 is used for non-productions servers and SMB Shares for backups. The Readynas has two 10GB base t, one of those NIC's is in a physically seperate (different switches) and seperate network (10.0.10.0/24) for Iscsi traffic (where VM's live), and the other NIC is on physically seperated network, used for SMB shares (10.3.81.1/24).
I have performed 2 balances, and each time I lose access to my ESXi hosts (they say "Not responding") and my only fix is to shut down and restart the NAS. I do wait until the balance is complete to do a shutdown, but I still cannot get access to my ESXi hosts after the balance is complete.
When I turn the ReadyNAS back on, all is well.
During the time the balance starts and when complete, and I loose access to ESXi hosts, the VM's on the EMC SAN are still running and I can RDP into them. I also get alerts of high access reads and writes to the datastores in the EMC SAN.
The VM's running on the Readnas, I can ping them...but I cannot RDP into them (until I reboot the ReadyNAS).
I am assuming the balance may be saturating the wrong network with iScsi traffic, but I wanted to see if anyone else has any issues when running a balance?
- Retired_MemberSep 16, 2017
Just an update, since I really dont like when people dont update a discussion.
On firmeware 6.8.0, and have had a Balance and defrag without issues. (so it seems Netgear has fixed the issue IMO)
- jak0lantashMentor
Retired_Member wrote:I am assuming the balance may be saturating the wrong network with iScsi traffic, but I wanted to see if anyone else has any issues when running a balance?
The BTRFS balance won't saturate any network interface, but it is stressful for the volume, so it may increase read and write latency, which maybe leads to issues. You said you lose access to ESXi hosts and that the RR4312 hosts datastore(s) and SMB shares. I'm not sure why you would lose access to the ESXi hosts while still reaching VMs, I would understand why some VMs would hang, but hosts? Are you running a nested environment? I don't understand why a balance on a storage device would cut you off from the hosts while you can still reach some VMs running on it.
Can you download the logs of the RR4312 and post here an extract of btrfs.log?
- Retired_Member
Label: '2fe72984:root' uuid: b1398ab0-5356-42be-b23e-f414e56d581d
Total devices 1 FS bytes used 561.41MiB
devid 1 size 4.00GiB used 2.05GiB path /dev/md0
Label: '2fe72984:TSS' uuid: 3709eb1d-0149-4884-8f68-3f11f380aecf
Total devices 1 FS bytes used 22.97TiB
devid 1 size 36.36TiB used 23.62TiB path /dev/md127
=== filesystem /TSS ===
Data, single: total=23.57TiB, used=22.94TiB
System, DUP: total=32.00MiB, used=3.00MiB
Metadata, DUP: total=27.50GiB, used=25.84GiB
GlobalReserve, single: total=512.00MiB, used=0.00B
=== subvolume /TSS ===
ID 257 gen 167454 top level 5 path .purge
ID 258 gen 204170 top level 5 path ._share
ID 259 gen 250423 top level 5 path .apps
ID 260 gen 255443 top level 5 path home
ID 261 gen 11 top level 5 path .vault
ID 262 gen 167447 top level 5 path .timemachine
ID 263 gen 255141 top level 5 path NAS_dev-ws
ID 264 gen 80205 top level 263 path NAS_dev-ws/.snapshots
ID 265 gen 32 top level 260 path home/TSS/gcarson
ID 280 gen 255306 top level 5 path NAS_veeam
ID 282 gen 52 top level 280 path NAS_veeam/.snapshots
ID 392 gen 254669 top level 5 path NAS_SQL
ID 393 gen 80194 top level 392 path NAS_SQL/.snapshots
ID 394 gen 254705 top level 5 path NAS_ORACLE
ID 395 gen 80185 top level 394 path NAS_ORACLE/.snapshots
ID 398 gen 373 top level 260 path home/TSS/veeam1_
ID 483 gen 1034 top level 260 path home/TSS/jharrison
ID 515 gen 250329 top level 5 path NAS_mdotbackup2
ID 516 gen 52358 top level 515 path NAS_mdotbackup2/.snapshots
ID 7840 gen 16938 top level 260 path home/TSS/yshao
ID 7873 gen 17056 top level 260 path home/TSS/rgreen
ID 8897 gen 255443 top level 5 path naslun1
ID 12780 gen 251293 top level 5 path NAS_mdotbackup1
ID 12782 gen 52352 top level 12780 path NAS_mdotbackup1/.snapshots
ID 18904 gen 204558 top level 5 path NAS_sccm
ID 18905 gen 80216 top level 18904 path NAS_sccm/.snapshots
ID 19190 gen 34811 top level 260 path home/TSS/sccm1_
ID 20249 gen 255443 top level 5 path naslun2
ID 21164 gen 49603 top level 260 path home/TSS/stg-app_
ID 21422 gen 52700 top level 260 path home/TSS/admin.service
ID 21666 gen 55685 top level 260 path home/TSS/dev-ws_
ID 33579 gen 167152 top level 5 path git
ID 33580 gen 167146 top level 33579 path git/.snapshots
=== btrfs dump-super /dev/md0 /dev/md127
superblock: bytenr=65536, device=/dev/md0
csum_type 0 (crc32c)
csum_size 4
csum 0xb771823b [match]
bytenr 65536
flags 0x1
( WRITTEN )
magic _BHRfS_M [match]
fsid b1398ab0-5356-42be-b23e-f414e56d581d
label 2fe72984:root
generation 152043
root 51445760
sys_array_size 129
chunk_root_generation 16925
root_level 0
chunk_root 20987904
chunk_root_level 0
log_root 0
log_root_transid 0
log_root_level 0
total_bytes 4290772992
bytes_used 588685312
sectorsize 4096
nodesize 16384
leafsize 16384
stripesize 4096
root_dir 6
num_devices 1
compat_flags 0x0
compat_ro_flags 0x0
incompat_flags 0x161
( MIXED_BACKREF |
BIG_METADATA |
EXTENDED_IREF |
SKINNY_METADATA )
cache_generation 18446744073709551615
uuid_tree_generation 152043
dev_item.uuid 5ae5ecc8-acb7-4d3b-90df-57704d75e19a
dev_item.fsid b1398ab0-5356-42be-b23e-f414e56d581d [match]
dev_item.type 0
dev_item.total_bytes 4290772992
dev_item.bytes_used 2198994944
dev_item.io_align 4096
dev_item.io_width 4096
dev_item.sector_size 4096
dev_item.devid 1
dev_item.dev_group 0
dev_item.seek_speed 0
dev_item.bandwidth 0
dev_item.generation 0
sys_chunk_array[2048]:
item 0 key (FIRST_CHUNK_TREE CHUNK_ITEM 20971520)
length 8388608 owner 2 stripe_len 65536 type SYSTEM|DUP
io_align 65536 io_width 65536 sector_size 4096
num_stripes 2 sub_stripes 0
stripe 0 devid 1 offset 20971520
dev_uuid 5ae5ecc8-acb7-4d3b-90df-57704d75e19a
stripe 1 devid 1 offset 29360128
backup_roots[4]:
backup 0:
backup_tree_root: 50757632 gen: 152042 level: 0
backup_chunk_root: 20987904 gen: 16925 level: 0
backup_extent_root: 50692096 gen: 152042 level: 1
backup_fs_root: 50397184 gen: 152042 level: 2
backup_dev_root: 30048256 gen: 147651 level: 0
backup_csum_root: 50462720 gen: 152042 level: 1
backup_total_bytes: 4290772992
backup_bytes_used: 588685312
backup_num_devices: 1
backup 1:
backup_tree_root: 51445760 gen: 152043 level: 0
backup_extent_root: 51314688 gen: 152043 level: 1
backup_fs_root: 51003392 gen: 152043 level: 2
backup_csum_root: 51052544 gen: 152043 level: 1
backup 2:
backup_tree_root: 49954816 gen: 152040 level: 0
backup_extent_root: 49790976 gen: 152040 level: 1
backup_fs_root: 50003968 gen: 152041 level: 2
backup_csum_root: 50102272 gen: 152041 level: 1
backup_bytes_used: 588677120
backup 3:
backup_tree_root: 50348032 gen: 152041 level: 0
backup_extent_root: 50266112 gen: 152041 level: 1
backup_bytes_used: 588681216
superblock: bytenr=65536, device=/dev/md127
csum_size 4
csum 0x430a8dee [match]
bytenr 65536
flags 0x1
( WRITTEN )
fsid 3709eb1d-0149-4884-8f68-3f11f380aecf
label 2fe72984:TSS
generation 255443
root 7407750316032
sys_array_size 129
chunk_root_generation 253996
root_level 1
chunk_root 36156708421632
chunk_root_level 1
log_root 0
log_root_transid 0
log_root_level 0
total_bytes 39983460909056
bytes_used 25251452792832
sectorsize 4096
nodesize 32768
leafsize 32768
stripesize 4096
root_dir 6
num_devices 1
compat_flags 0x0
compat_ro_flags 0x0
( MIXED_BACKREF |
BIG_METADATA |
EXTENDED_IREF |
SKINNY_METADATA )
uuid_tree_generation 255443
dev_item.uuid 8f73134e-0657-4750-a01c-ac6de62bbcd7
dev_item.fsid 3709eb1d-0149-4884-8f68-3f11f380aecf [match]
dev_item.type 0
dev_item.total_bytes 39983460909056
dev_item.bytes_used 26105952075776
dev_item.devid 1
item 0 key (FIRST_CHUNK_TREE CHUNK_ITEM 36156708225024)
length 33554432 owner 2 stripe_len 65536 type SYSTEM|DUP
num_stripes 2 sub_stripes 1
stripe 0 devid 1 offset 604621504512
dev_uuid 8f73134e-0657-4750-a01c-ac6de62bbcd7
stripe 1 devid 1 offset 604655058944
backup_roots[4]:
backup 0:
backup_tree_root: 7407750316032 gen: 255443 level: 1
backup_chunk_root: 36156708421632 gen: 253996 level: 1
backup_extent_root: 7407735472128 gen: 255443 level: 2
backup_fs_root: 644336418816 gen: 204171 level: 0
backup_dev_root: 6245190500352 gen: 253996 level: 1
backup_csum_root: 7407717056512 gen: 255443 level: 0
backup_total_bytes: 39983460909056
backup_bytes_used: 25251452792832
backup 1:
backup_tree_root: 7407741272064 gen: 255440 level: 1
backup_extent_root: 7407725740032 gen: 255440 level: 2
backup_csum_root: 7407713648640 gen: 255441 level: 0
backup_bytes_used: 25251452764160
backup 2:
backup_tree_root: 7407748972544 gen: 255441 level: 1
backup_extent_root: 7407728394240 gen: 255441 level: 2
backup_csum_root: 7407716925440 gen: 255442 level: 0
backup_bytes_used: 25251452768256
backup 3:
backup_tree_root: 7407747170304 gen: 255442 level: 1
backup_extent_root: 7407737438208 gen: 255442 level: 2
backup_bytes_used: 25251452784640
- Retired_Member
I am guessing at this too, since the ReadyNAS is the only new thing added to my network...when I had my support ticket with VMware the only thing I did to bring back my ESXi hosts....was turn off the ReadyNAS. A few days later I did a "Balance" again.....with same resutls...In vCenter the ESXi hosts stated "not responding"...I could not log into the hosts of each ESXi server. I again shut off the ReadyNAS and all came back online.
- mdgm-ntgrNETGEAR Employee Retired
Your volume doesn't need balancing. It's well balanced looking at the output you've provided.
