mdgm-ntgr
Feb 05, 2011NETGEAR Employee Retired
SBS 2011 and ESXi
I was thinking of maybe getting a ReadyNAS to use as NFS storage for a new ESXi server to replace any ageing setup. Which ReadyNAS would you recommend for this new setup? Currently we're using an a...
bbaraniec
May 12, 2011Luminary
mdgm wrote: So why not go with SAS then as they are more reliable?
Depends on your budget really. SAS are much more expensive then SATA.
mdgm wrote: I have AD, file server, Papercut (print charging software), Exchange, some Time & Cost software and an accounting program that uses SQL.
I haven't migrated SBS AD so I can't tell if how long does it takes. I seems that is pretty easy, there is migration tool for SBS 2011.
I have found this article: http://www.smoothblog.co.uk/2011/01/06/ ... -sbs-2011/
File server that is pure rsync, SQL shouldn't be a problem backup->restore. I have done this many times. I never migrated Exchange thou but I know someone who did.
I ask him how the process looks like.
- Jul 18, 2017Retired_Member
