mdgm-ntgr
Feb 05, 2011NETGEAR Employee Retired
SBS 2011 and ESXi
I was thinking of maybe getting a ReadyNAS to use as NFS storage for a new ESXi server to replace any ageing setup. Which ReadyNAS would you recommend for this new setup? Currently we're using an a...
CappyKD
May 12, 2011Aspirant
And SAS drives fail plenty, especially the SFF ones, the 3.5" ones seem much better, but with SAS you are also limited in capacity vs SATA. I was asking about ESXi nics, not SBS nics. For an optimal setup you should run 4, one for management two for iSCSI and one for the vm's. And I would run iSCSI for the storage vs. nFS.
CappyKD
CappyKD
- Jul 18, 2017Retired_Member
