mdgm-ntgr's avatar
mdgm-ntgr
NETGEAR Employee Retired
Feb 06, 2011
SBS 2011 and ESXi
I was thinking of maybe getting a ReadyNAS to use as NFS storage for a new ESXi server to replace any ageing setup. Which ReadyNAS would you recommend for this new setup?
Currently we're using an ageing SBS 2003 OEM server, with a Pentium IV 3Ghz Processor and 4GB RAM installed (3.25GB can be used)
It works fine however it doesn't meet the requirements of some new software we need to use.
So I was thinking with SBS 2011 now released it would be a good time to upgrade our systems.
I was thinking maybe this server would be good: http://betterit.com.au/scripts/prodview ... uct=141001
Should I get SAS disks (if so which ones) or enterprise SATA disks.
I was a bit shocked when I read the system requirements for SBS 2011: http://www.microsoft.com/sbs/en/us/syst ... ments.aspx
What's so special about SBS 2011 that it needs a quad-core processor? Why wouldn't a dual-core suffice?
Ideally I would've liked to have just migrated our SBS 2003 installation onto a new server. However as we have the OEM version this isn't possible. So I'd like to get a Retail or Volume License version of SBS 2011 (which do you recommend?)
Also I was thinking using ESXi would be a better way of doing things in case we wish to get the Premium Add-on down the track and also to make it easier to move to a new server if the current server fails.
I'd like to be able to separate hardware upgrades from OS upgrades when it comes to the server. As an SBS migration is a time consuming task.
Any advice on how to migrate from SBS 2003 to 2011 such as good sites to look at?
Also how much downtime will this lead to?
  • Mdgm, I am starting to go through the same process, I was wondering if you have updated to sbs 2011 and what worked and did not work, my initial thoughts were that I am going to go with xenserver but I am still open. I have a current sbs2003 setup and want to go to new system and go all virt for the servers, I was planning on having the VM's data stors on a readyNAS pro 6 model, and the physical machine just the bare install server, but house all of the data on the NAS. Still working on replication/backup and how I am going to handle that. I too have been debating nfs vs iscsi no decisions committed but would love to here what work/worked and what did not. Thanks.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    At the moment I'm thinking I probably won't virtualise.
    Any particular reason that changed your mind?
    mdgm-ntgr
    The cost. For one server it can be hard to justify the cost of virtualising. When you have multiple VMs to run it starts to become quite attractive.
    Yeah I hear you but it has it's advantages, the one major thing I like is the restore time, it's basically hardware independent, if you have a hardware failure I could almost through any supported hardware to get them back up as fast as possible. I already have my build pretty much spec'd out and it's no more than the cost of one of the laptop's I just bought for one of my users. So for my build I'm right at around $1200 (us), for the server not including my readynas 6 and drives. I was going to do the Nas anyway so that part would be a push, even if I went internal raid, it's cheaper but not by a whole lot since I would still need the same number of drives, the controller card would be cheaper than the NAS but then It's less flexible. So for ~$1200 this is what I have:
    3u rack case
    SUPERMICRO MBD-H8SGL-F G34 AMD M/B
    amd Magny Cour 2.0G 8 core processor
    G34 CPU cooler
    32G Kingston ECC registered Memory
    Antec 380 Power supply
    4bay hot swap 2.5 HDD cage
    Intel 40G SSD
    antec 380W Power supply
    For about $250 more supermicro makes a 1ru server chassis system just for this motherboard, all ready to go, just add memory, cpu and drives...I still may go with it... http://www.supermicro.com/Aplus/system/ ... 2G-MTF.cfm
    I use Supermicro for almost all of my server builds, they make good stuff and have good support. The cool thing about the g34 boards is that they are supposed to stay compatible with the new 16 core bulldozer lines that are coming out...so one should be able to get a long life out of it...just thought I'd pass that along..:)
ProSupport for Business
