mitumix
Sep 12, 2014Aspirant
Scheduled Backup With Overwrite
Hi I searched for the forum but didn't find what I was looking for. I wish to backup my desktop at regular intervals but I do not want to keep all the backups. My desktop is synced with the ...
mitumix
Sep 17, 2014Aspirant
Hi Guys
Thanks for the suggestions.
Issues : Buying a software is out of question unless it is free. The problem is functionality is not provided by the GUI nor additional apps. SSH is ok but it will run off a PC. Can SSH run inside the NAS? I think there should be an Advanced Tab for these sort of activities and best practices templates.
I have decided to use the built in feature, where after 4 weeks(which is the max) it will do a FULL BACKUP and do a delete lot of existing files. Which means, the daily backups will be incremental.
FYI Firmware: RAIDiator 5.3.7
Right now, my issue is active sync with desktop and nas as windows 7 offlines and sync center turns out to be unreliable. :( THis I have posted as a new thread.
