Sandshark
Dec 24, 2020Sensei
Script for making remote NAS diagnostics available locally
StephenB suggested starting this. Obviously, it's for advanved users with at least some Linux experience. I have one main NAS, two local backup NAS, and a remote backup NAS. Since the backup de...
Dec 25, 2020Guru - Experienced User
I haven't installed hdsentinal, so I'll need to take a look at that.
You can get quite a bit of info with smartctl (including stuff that isn't in the log zip), and I was thinking about using that.
This gives you a lot of info on the installed disks:
for i in a b c d e f g h i j k l m n; do smartctl -a -x -l defects /dev/sd${i} | egrep -v "local build|No such device|smartmontools"; done >>smart.log
Though if you want to be more selective on the smart stats you can also do something like
for i in a b c d e f g h i j k l m n; do smartctl -a /dev/sd${i} | egrep -i "Device Model|Serial Number|Reallocated_sec|ATA Er|offline_uncorrect|current_pending_sector|Power_on"; done >>smart.log
tailoring the egrep string to include the specific parameters you want to track. mdgm suggested this version to me a few years ago now (it is also handy in tech support mode).
