slayerduck's avatar
slayerduck
Seagate 1.5TB to Samsung 2TB Smart failed
I'm replacing my Seagate ST31500341AS [1397 GB] with SAMSUNG HD204UI [1862 GB] one by one on my Readynas NV+ and currently its syncing the 2th disk. Then i got the shock of my life while this error message popped up:
Disk 1 did not pass SMART self-assessment test. Please replace this disk as soon as possible. Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
This is the drive i just replaced. Here is the smart data:
SMART Information for Disk 1
Model: SAMSUNG HD204UI
Serial: S2H7J1AB203186
Firmware: 1AQ10001
SMART Attribute
Raw Read Error Rate 0
Throughput Performance 0
Spin Up Time 64398
Start Stop Count 2
Reallocated Sector Count 0
Seek Error Rate 0
Seek Time Performance 0
Power On Hours 40
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 2
G-Sense Error Rate 0
Power-Off Retract Count 0
Temperature Celsius 31
Hardware ECC Recovered 0
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
Load Retry Count 0
Load Cycle Count 2
ATA Error Count 0
Extended Attribute
Hot-add events 1
Hot-remove events 1
Lp stat events 24143
Power glitches 0
Hard disk resets 2
Retries 1
Repaired sectors 0
Personally i don't see anything wrong with the drive, can i safely continue replacing the other disks? I don't see why it would say it did not pass SMART?
  • The Samsung disk is not on the Hardware Compatibility List for the NV+. In fact no Samsung 2TB drive is on the list.
  • Did the same thing and I got the same message. Did you ever get it resolved?
  • The HD204UI is a 4K sector HDD. If your original HDD's where 512 byte sector based (high probability they were) then the only way to properly align them is by performing a factory reset with the new drives in place.
    A FACTORY RESET WILL WIPEOUT EVERYTHING ON THE DISKS INCLUDING DATA!!!
    You can verify your alignment by...
    Download the logs via Status > Logs > Download all Logs. Unzip. The contents of partition.log will indicate whether you have 4k sector alignment.
    You're looking for something similar...
    Device Boot Start End Blocks Id System
    /dev/hdc1 32 4096031 2048000 83 Linux
    Partition 1 does not end on cylinder boundary.
    /dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
    As you can see, the start numbers e.g. 32, are divisible by 8 indicating that the partitions are aligned properly for 4k sectors.
    What version of RAIDiator are you using?
    I'm not sure if it would cause SMART errors but it's a place to start.
    Also, what browser are you using to view Frontview (and the SMART errors)? I have noticed that in Internet Explorer the SMART data doesn't seem to update like it should, whereas Firefox will properly show the current data.
ProSupport for Business
