ifixidevices
Oct 04, 2015Luminary
Seagate 8TB Archive drives (ST8000AS0002) do work
Just thought I'd pass along in case anyone was curious of the 8TB drives work or not. So far in testing a Pro 6 and an Ultra 6 I have 3 8TB drives in the pro 6 and 2 in the ultra 6 (with another one ...
powellandy1
Oct 12, 2015Virtuoso
Interesting... mine are AR13.
Did you factory reset at any point from 6.4.0 -> 6.4.0 T112 -> 6.2.4
ifixidevices
Oct 12, 2015Luminary
You have to factory reset once back down to 6.2.4 (after you've installed it.)
So backup your data then once downgraded go from there.
This could be a think with the ultra models versus the pro or other models... I have no idea. I have to hook my drives up to the rn104 and see if I'm seeing the same issues (at this point they already have a ton of errors showing on the smart data so I don't feel comfortable using them... that's why I kind of feel like the firmware ruined them.. prior to that no problems.
- powellandy1Oct 12, 2015Virtuoso
I know what you mean!!
So far on mine the only SMART 'errors' are command timeouts (39 and 6 respectively) - and whilst being no expert I wonder if this is artifactual from it being hit with too many commands whilst the 'SMR stuff' internally catches up.I have an RN102 coming soon so may try them in that to see if ARM v. x86 makes a difference.
Thanks for the advice. Will reset on 6.2.4. These drives are the backup of my other NASes - the idea was to eventually have 4x8TB glad I stopped at 2 until this is sorted as they aren't cheap!
Can't you RMA them if they have loads of SMART errors?? Do they pass SeaTools still??
A
- powellandy1Oct 13, 2015Virtuoso
Back on 6.2.4, thanks. Will update here - https://community.netgear.com/t5/Using-your-ReadyNAS/8TB-Drive-drops-out-of-JBOD-volume-on-6-4-0-on-Ultra4/m-p/992765#M95329.
