dafreaki
Oct 12, 2014Aspirant
Seagate Expansion USB 3TB on connected to the rear ports on
posting here in hopes of getting an answer on why my 2 x Seagate Expansion USB 3TB on connected to the rear ports on my Duo v2 wont work correctly i keep getting input/output error on backups and when...
vandermerwe
Oct 12, 2014Master
So the disks were mounted on the duo and you removed them without dismounting them in the GUI? If so this may be the problem. Did you format them on a PC or from the nas?
Have you tested the 3 tb disks?
Are the USB disks AC powered?
