dafreaki
Oct 12, 2014Aspirant
Seagate Expansion USB 3TB on connected to the rear ports on
posting here in hopes of getting an answer on why my 2 x Seagate Expansion USB 3TB on connected to the rear ports on my Duo v2 wont work correctly i keep getting input/output error on backups and when...
vandermerwe
Oct 12, 2014Master
Have you tried a different format ? Ext3?
I'd still check them thoroughly with sea tools, the disks may seem ok but I/O errors suggest a hardware or file system problem.
Maybe the USB disks are not compatible?
