devs1
Dec 04, 2011Aspirant
Seagate GoFlex External USB 2TB
Hi guys, I've got a NasDuo running RAIDiator : 4.1.7 and am trying to back the data up to an external Seagate GoFlex External USB 2TB. So far I've changed the drive so that it does not sleep to avoid ...
mdgm-ntgr
Dec 05, 2011NETGEAR Employee Retired
When you format the disk using Disk Utility (Applications > Utilities > Disk Utility) on a Mac, the MBR (Master Boot Record) partitioning scheme can be selected under options. Then connect the disk to the NAS again and format it to use EXT3.
