devs1
Dec 04, 2011Aspirant
Seagate GoFlex External USB 2TB
Hi guys, I've got a NasDuo running RAIDiator : 4.1.7 and am trying to back the data up to an external Seagate GoFlex External USB 2TB. So far I've changed the drive so that it does not sleep to avoid ...
mdgm-ntgr
Dec 05, 2011NETGEAR Employee Retired
Good.
The NV+ (v1) does not support GPT partitioning, hence the 2TB limit on capacity of the drives you can use internally/externally. If a disk less than 2TB in capacity is formatted to use GPT partitioning this will still cause problems, so the simple solution is to reformat them to use the older MBR partitioning scheme that is compatible.
