Nasfandago
Feb 20, 2019Aspirant
Securely delete NAS data before resale
Hello All, I am an owner of a Netgear ReadyNAS 10400. Although the NAS has served me well i have outgrown its capacity and now must say farewell to it, this will probably be by means of eBay. ...
Nasfandago
Thanks for the reply Mark. Do you know if 'Doing a Factory reset permanently deletes your data' does anything technical to ensure that ? Such as writing blank data over my old data ? Certainly could look to use 3rd party software in another PC to do that but was hoping NetGear already did something like this to save that hassle.
I might sell the drives separately as suggested. As the drives have some value I’m not wanting to physically destroying them at this time, as fun as it sounds.
Feb 20, 2019Guru - Experienced User
It will reformat the drives, but that might not fully erase your user data. So it is conceivable that RAID recovery tools like ReclaiMe could find some of it.
I believe cipher assumes ntfs formatting, so it's not a good tool for this. In particular, it might not encrypt free space. I suggest using the write-zeros tools in lifeguard or seagate.
