RoBa
May 11, 2018Star
Serial number is changed to NONE000200000 and mac address is changed to 00: 50: 43: 02: 00: 00 RN102
Hi, after a raidar malfunction reported "management service is offline". Then I removed the discs and tried to reset the S.O. Now I connect as an administrator but I notice a very strange thing: the ...
- May 11, 2018
Thanks for the invaluable help. Excellent assistance and fast. Thanks again
I know the Bad disk, is only for a try, thanks
Can I insert the disks that were originally mounted on the NAS?
But I do not remember the slot can I identify them in some way having the ability to read them from linux ?
mdgm-ntgr
May 11, 2018NETGEAR Employee Retired
This should be easy to fix.
Did you recently update the firmware, especially from pre-6.4.x firmware to 6.4.x (or later)?
