RoBa
May 11, 2018Star
Serial number is changed to NONE000200000 and mac address is changed to 00: 50: 43: 02: 00: 00 RN102
Hi, after a raidar malfunction reported "management service is offline". Then I removed the discs and tried to reset the S.O. Now I connect as an administrator but I notice a very strange thing: the ...
- May 11, 2018
Thanks for the invaluable help. Excellent assistance and fast. Thanks again
I know the Bad disk, is only for a try, thanks
Can I insert the disks that were originally mounted on the NAS?
But I do not remember the slot can I identify them in some way having the ability to read them from linux ?
mdgm-ntgr
May 11, 2018NETGEAR Employee Retired
This should be easy to fix.
Did you recently update the firmware, especially from pre-6.4.x firmware to 6.4.x (or later)?
RoBa
May 11, 2018Star
I was already at the latest version 6.9.3 I would say as soon as it came out maybe a few months ..
- mdgm-ntgrMay 11, 2018NETGEAR Employee Retired
I can see a factory reset was done on 6.9.1 and it was updated to 6.9.3 shortly thereafter.
The NAS is now up with the correct serial number.
The disk currently in the NAS is bad though.
- RoBaMay 11, 2018Star
- SandsharkMay 13, 2018Sensei
If you've saved an old log .zip file, then the information you need is in disk_info.log within the .zip.
