augur
Oct 19, 2021Apprentice
Set same username and group on filesystem for every access
Hi, I own three ReadyOS6 NAS and use Resilio Sync App for synchronzing everything in between also via WAN. It works really fine but if I upload a file via ReadyCloud from my iPhone it is saved wi...
Oct 20, 2021Guru - Experienced User
augur wrote:if I upload a file via ReadyCloud from my iPhone it is saved with ReadyCloud user and group as owner. With this Resilio Sync does not work anymore. It depends on "admin" as owner.
Can you post a similar screenshot before you've changed the owner/permissions? I'm wondering if this is a permissions issue.
FWIW, I use Rsync for NAS<->NAS backup, but I do have Resilio Sync running on a PC and use it to back up my iPhone photos.
augur
Oct 21, 2021Apprentice
I use it also to sync my Phone, Laptop and my NAS. NAS <-> NAS Backup is running RSync.
Resilio Sync has issues if the process user is not the same as the file owner. It could not change some fileproperties then which is necessary sometimes and then leads into sync issues. That is a known issue...
Normally I use Resilio Sync only but sometimes I like to access the files on the NAS directly e.g. from a laptop of my wife who has not every synced. After this I have issues mostly if I do not use the admin user for this. Also it is a private solution with 4 users. :-)
I cannot show the file list before as I corrected it (set a default user via GUI) and then thought I should ask here.
- StephenBOct 21, 2021Guru - Experienced User
Does this problem happen when the folder on the NAS has the file access set to allow everyone read/write access?
Have you also tried checking the "grant rename and delete privileges" box (ignoring the bit that talks about AFP/NFS)?
- augurOct 21, 2021Apprentice
Yes, both does not help. I reset everytime to admin.
