ephemeris
Mar 20, 2014Aspirant
Set Up Dual Redundancy without RAIDar?
I just did a factory reset on my ReadyNAS Pro. I tried to follow instructions in the manual to set up XRAID2 with dual redundancy. I used RAIDar to get to SETUP chose the XRAID2 but no option for dual...
Mar 20, 2014Guru - Experienced User
Personally I prefer doing it your way; it avoids the need to work within the 10 minute window.
ephemeris wrote: ...Yes I went ahead and started over with 5 disks and will add the sixth when it finishes syncing. Unless you have a better idea :-)
