peet1
Nov 06, 2016Guide
Setup wizard will not start after USB recovered 6.6 on Readynas Pro Pioneer
I upgraded My Pro Pioneer to 6.6. It was working well but in an un-related screw up on my part it was acting up, so I used a USB recovery tool to lay down a fresh 6.6. I've done the same thing sever...
mdgm-ntgr
Nov 06, 2016NETGEAR Employee Retired
You should only do USB Boot Recovery if there is a problem on the internal flash. Usually USB Boot Recovery is done when it isn't needed.
- peet1Nov 06, 2016Guide
That makes sense.
Yeah, I won't lie, USB recovery is a lazy way for me to get the result that I want.
However, I don't necesarily think my current issue is caused by the recovery. My first recovery was from the internal flash and I ran ito the same issue.
Cheers.Peet
- mdgm-ntgrNov 07, 2016NETGEAR Employee Retired
It may/may not have been the case here but often when USB Boot Recovery there is a problem with something on the disks e.g. the OS partition and nothing wrong at all with the firmware on the internal flash. USB Boot Recovery's sole purposes is to wipe the flash, format it and put a clean copy of the firmware on it.
If the problem is not with the internal flash then you risk creating an additional problem without fixing any.
