dschwartzer
Jan 01, 2017Luminary
Several Backup Questions
I have searched the community boards for some help but haven't found what I need. I apologize in advance if this is a duplicatre. I have a RN526X as my main server and a RN314 which is set up on...
bedlam1
Jan 01, 2017Prodigy
In answer to your question 1 just set the source as volume: data
This works for me
dschwartzer
bedlam1:
Thanks for the quick response.
I tried this originally but couldn't get it to work. I set the Source to data with the Patrh field empty. I enter the IP address of the 314 and also leave the Path blank. (anything I put in the Path causes the connection to fail). With leaving the Path blank, I Test the connection and I get a confirmation that the connection to the 314 is successful.
When I try to run the backup it goes from Startin to In Queue to Failed. The error message says:
Error backup job DataBackup: connection cannot be established. Check the connection and authentication, if required.
Any idea what I am doing wrong?
