patchie1
Dec 04, 2013Aspirant
SFTP Sync
Hi, Is it possible for me to sync a folder via SFTP with a remote server? Is there a SFTP client app or something i can use? Some of these maybe? http://apps.readynas.com/pages/?page_id=9 ...
Dec 10, 2013Guru - Experienced User
rebby's reply is responsive - if you log into the NAS you can run rsync over ssh as a client, the link would be encrypted, and would not reveal your credentials. You would need to get the public ssh key from the online server, and install it into the ssh authorized_keys file. If the remote server supports rsync, that will work - though it can be tricky to set up.
Super-poussin includes the Monsta FTP client in his add-on dropbox (viewtopic.php?f=153&t=70914). There's an overview here: http://www.noupe.com/freebie/monstaftp- ... 78481.html
Monsta doesn't support SFTP, but it does support FTPS (otherwise known as FTP-SSL).
