patchie1
Dec 04, 2013Aspirant
SFTP Sync
Hi, Is it possible for me to sync a folder via SFTP with a remote server? Is there a SFTP client app or something i can use? Some of these maybe? http://apps.readynas.com/pages/?page_id=9 ...
Dec 11, 2013Guru - Experienced User
rsync is normally run incrementally. It doesn't run all the time, you would set up a schedule.
It is a CPU hog, but I run it on my RN102 (locally backing up my Pro) and it keeps up easily. In your case, I think the speed is likely be limited by your internet uplink. How fast is your connection?
FTPS is secure, so it is another possibility.
