dschwartzer
May 07, 2017Luminary
Shares now Read Only after Updating to 6.7.1
I have an RN526X as my primary server and use a RN314 as a backup server. Yesterday, I upgraded both systems to OS 6.7.1 Each night at 10:00, the RN 526 sends an incremental backup to a folder o...
vandermerwe
May 07, 2017Master
I have exactly this issue since I upgraded to 6.7.0 and subsequently to 6.7.1 betas and final. I have ReadyDR backups to an Ultra 6 plus from a 316.
Thread is here:
I have needed to reset the unit 4 times in the last few weeks. I am now not using ReadyDR and the problem has not recurred.
The logs were full of errors which I was told was related to filesystem corruption - these errors made the system force a change to read only
The disks are all OK after thorough testing and the NAS memory is fine.
I will eventually restart ReadyDR and I suspect the problem will recur when I do.
Perhaps have a look at your logs - system journal particularly , to see if you have similar errors, although I would be interested to see what mdgm has to say after looking at your logs.
