dschwartzer
May 07, 2017Luminary
Shares now Read Only after Updating to 6.7.1
I have an RN526X as my primary server and use a RN314 as a backup server. Yesterday, I upgraded both systems to OS 6.7.1 Each night at 10:00, the RN 526 sends an incremental backup to a folder o...
dschwartzer
May 08, 2017Luminary
Since this server is only used for backup I decided to restore it to factory default and I can now create new folder and have read/write access again. I have recreated the backup job from the 526 to the 314 and it appears to be running successfully (it is still running).
I am trying to re-set-up the Ready DR jobs but I cannot upload the Access Key from the 526 to the 314. I download the key without issue but when I try to upload it to the 314 I get an error box. There is no description or code, it just says error.
As I recall there is nothing special about uploading the key. Am I missing a step in stting this up?
Thanks,
David
evan2
May 09, 2017NETGEAR Expert
See your logs, all disks have below errors, please check volume.log file
Reallocated Sectors: 2
Reallocation Events: 2
and btrfs filesyste has errors, then volume force to readonly, please check systemd-journal.log
Could do you please backup your data on NAS? then format all disk,
I suggest you had better replace all disks because all disks have reallocated errors.
May 07 00:00:21 ReadyNAS314 replisync[7577]: MusicDR: receiver: Receiving from ReadyNAS526 (2fe6e954): /data/MusicDR/.snapshots/182
May 07 00:00:22 ReadyNAS314 kernel: BTRFS error (device md127): parent transid verify failed on 635994112 wanted 8866 found 8926
May 07 00:00:22 ReadyNAS314 kernel: BTRFS warning (device md127): Skipping commit of aborted transaction.
May 07 00:00:22 ReadyNAS314 kernel: ------------[ cut here ]------------
May 07 00:00:22 ReadyNAS314 kernel: WARNING: CPU: 1 PID: 7598 at fs/btrfs/transaction.c:1853 cleanup_transaction+0x82/0x270()
May 07 00:00:22 ReadyNAS314 kernel: BTRFS: Transaction aborted (error -5)
May 07 00:00:22 ReadyNAS314 kernel: Modules linked in: vpd(PO)
May 07 00:00:22 ReadyNAS314 kernel: CPU: 1 PID: 7598 Comm: btrfs Tainted: P O 4.4.62.x86_64.1 #1
May 07 00:00:22 ReadyNAS314 kernel: Hardware name: NETGEAR ReadyNAS 314/To be filled by O.E.M., BIOS 4.6.5 11/05/2013
May 07 00:00:22 ReadyNAS314 kernel: 0000000000000000 ffff880010ab7a80 ffffffff883cf3c8 ffff880010ab7ac8
May 07 00:00:22 ReadyNAS314 kernel: ffffffff88cec0b7 ffff880010ab7ab8 ffffffff8806b25c ffff88006ab14f30
May 07 00:00:22 ReadyNAS314 kernel: ffff88007bb5e000 ffff88007c351390 00000000fffffffb ffff88007bb5e000
May 07 00:00:22 ReadyNAS314 kernel: Call Trace:
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff883cf3c8>] dump_stack+0x4d/0x65
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff8806b25c>] warn_slowpath_common+0x7c/0xb0
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff8806b2d7>] warn_slowpath_fmt+0x47/0x50
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff882ea962>] cleanup_transaction+0x82/0x270
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff8809f680>] ? wait_woken+0x80/0x80
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff882ecb34>] btrfs_commit_transaction+0x964/0xa30
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff883203f7>] btrfs_mksubvol+0x537/0x550
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff8832059c>] btrfs_ioctl_snap_create_transid+0x18c/0x1a0
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff88320742>] btrfs_ioctl_snap_create_v2+0x102/0x150
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff883253df>] btrfs_ioctl+0x133f/0x2d30
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff8814958d>] ? do_filp_open+0x8d/0xd0
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff88172a04>] ? fsnotify+0x384/0x470
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff8814b745>] do_vfs_ioctl+0x2b5/0x480
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff8814881f>] ? putname+0x4f/0x60
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff8814b984>] SyS_ioctl+0x74/0x80
May 07 00:00:22 ReadyNAS314 kernel: [<ffffffff88a4b717>] entry_SYSCALL_64_fastpath+0x12/0x6a
May 07 00:00:22 ReadyNAS314 kernel: ---[ end trace f5649e008d2444b5 ]---
May 07 00:00:22 ReadyNAS314 kernel: BTRFS: error (device md127) in cleanup_transaction:1853: errno=-5 IO failure
May 07 00:00:22 ReadyNAS314 kernel: BTRFS info (device md127): forced readonly
