dschwartzer
May 07, 2017Luminary
Shares now Read Only after Updating to 6.7.1
I have an RN526X as my primary server and use a RN314 as a backup server. Yesterday, I upgraded both systems to OS 6.7.1 Each night at 10:00, the RN 526 sends an incremental backup to a folder o...
dschwartzer
May 09, 2017Luminary
Thanks for your note. Please see my follow up post directly above yours.
I did do a factory reset of the NAS (twice) and now do have read/write access. That said, it looks like there is still an issue with the file system as it will not allow me to upload the access key for the ReadyDR function.
I have also tried another manual install of the 6.7.1 firmware but that did not change anything.
Other than that, it seems like the NAS is running correctly again.
A screen shot if the error is included above.
Thoughts?
Thoughts?
- Retired_MemberMay 09, 2017
Hello dschwartzer
can you please try to clean web cache or change a web browser then upload key again?I just tested key uploading on both 6.7.1 devices without issue.
- dschwartzerMay 10, 2017Luminary
Thanks for your reply. Clearing the browser in Chrome did not help but switching to the Safari (Mac) browser did allow mew to upload the Access Key.
That said, after uploading the key to the 413, I re-setup the ReadyDR shares on the 314 but all of the ReadyDR jobs failed. In checking the history there is sometimes a message that says Broken Pipe. Most of the times the ReadyDR jobs just say Running but never complete and nothing is written to the 314, and I have to cancel the jobs manually.
I know the 314 is on the network and visible to the 526 because a Backup job backing up the entire data volume to a Share on the 314 continues to run fine every night at 10:00 PM.
Any ideas what I am doing wrong?
David
- Retired_MemberMay 11, 2017
Broken Pipe should be related with network issue,can you please send latest system log again?
