dschwartzer
May 07, 2017Luminary
Shares now Read Only after Updating to 6.7.1
I have an RN526X as my primary server and use a RN314 as a backup server. Yesterday, I upgraded both systems to OS 6.7.1 Each night at 10:00, the RN 526 sends an incremental backup to a folder o...
Retired_Member
May 09, 2017Hello dschwartzer
can you please try to clean web cache or change a web browser then upload key again?I just tested key uploading on both 6.7.1 devices without issue.
dschwartzer
May 10, 2017Luminary
Thanks for your reply. Clearing the browser in Chrome did not help but switching to the Safari (Mac) browser did allow mew to upload the Access Key.
That said, after uploading the key to the 413, I re-setup the ReadyDR shares on the 314 but all of the ReadyDR jobs failed. In checking the history there is sometimes a message that says Broken Pipe. Most of the times the ReadyDR jobs just say Running but never complete and nothing is written to the 314, and I have to cancel the jobs manually.
I know the 314 is on the network and visible to the 526 because a Backup job backing up the entire data volume to a Share on the 314 continues to run fine every night at 10:00 PM.
Any ideas what I am doing wrong?
David
- Retired_MemberMay 11, 2017
Broken Pipe should be related with network issue,can you please send latest system log again?
- dschwartzerMay 12, 2017Luminary
I am currently traveling until 5/22 but will submit the logs as soon as I return.
- dschwartzerJun 08, 2017Luminary
Sorry it has taken so long to follow-up on this. I'm not sure of it is a coincidence or not but upgrading both the 526X and 314 to the current 6.7.14 firmware seems to have resolved the problem.
After upgrading, I reloaded the Access Key and recreated the DR shares. The first backup was done manually to see if they would complete. After that, I have had two days of automatic backup of the Snapshots so from my perspective, this issue is resolved for me.
I'm not sure I should mark this as resolved since others have joined the discussion with the same issue.
Thanks for the help.
David
