dvkch
Sep 20, 2012Aspirant
Sharing whole C volume
Hi I would like to know if this is possible to share the whole "C" volume . I used to own a DLink DNS320 which was sharing the whole volume Volume_1, and then you could configure other shares to a ...
Dec 29, 2012Guru - Experienced User
Not sure why the combination of HomeNAS and DriveC is important, it seems to me that you'd get the same behavior with just DriveC as the root.
littomalt wrote: I'm not sure if this is your solution but for me this is working
I make one share and cal it "HomeNAS"
in home nas i have one directory called DriveC, and under i have several directories, like TV, Video, Pictures, Documents Child 1, Cild 2, Wife, etc
Setting permissions is not so good, because i have not found if its possible to give different access to a directory per user, ie TV read only for all, Documents Child 1 R/W.
If anybody know how to do this pleas inform me :-)
But what is nice is that i can mount all NAS in one drive on my PC, i map DriveC to N:, and of course i can mount t: to DriveC/TV and so on, this i do the children's computers like P: mount to DriveC/Child1. I find this better than home directories due to a simpler backup to ie jottacloud.no (they only allow one share - Like my N: drive - to be backed up and this way i backup all data from one share)
If you use admin credentials for the mapped drives you can also mount the NAS C volume directly (mount \\nasip\c)
